Salta al contenuto principale
Informazioni su riparazione, smontaggio e soluzione problemi per Steam Deck OLED, un aggiornamento del 2023 della popolare console videogame portatile prodotta da Valve. Rilasciata il 16 novembre 2023. Identificata dal numero di modello 1030.
Steam Deck OLED Screen Problem
Hello everyone. my steam deck OLED is out of warranty, and I live in southeast Asia; it is impossible to send my deck to valve because the repair cost and delivery cost will be more expensive than getting a new one.
So, my steam deck OLED has problem with the screen. when it is on the home menu and I press the backplate of my deck, it shows some stripes and flicker. and when I play some demanding games, sometimes it can stand for an hour, and sometimes it can't even stand for 5 mins. And after the screen goes black, I still can hear the sound of my game e.g. the steps when I walk around / the sound of pause menu and I still can shut down my deck using my feeling while the screen goes black.
When I connect my steam deck to the dock, I have 0 problem. tried to benchmark my deck for hours with hitman WOA benchmark and play some games after that, it works with 0 problem.
But I notice something, when the screen acts up, and I docked my deck, it shows no signal. I had to restart my deck while it is docked so my monitor can get the signal.
What I already do:
Teardown my deck, change the thermal paste, clean the ribbon cable of the screen, clean the connector of the screen on the motherboard.
So, what do you think is wrong with my deck? I asked around, some people said it is the display and some people said it is the CPU/GPU. I had no problem with replacing the screen by myself. but the OLED screen is not cheap, so I just worried if it is not the screen that has a problem.
What makes me worried if it is the CPU/GPU is when my screen is normal, I can dock my deck normally. but when the screen is act up and I docked it, my monitor shows no signal
Steam Deck OLED screen problem
*Sorry for my bad English
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta più utile
Hi!
Since there are no issues when docked, I think it’s the screen itself and especially something with the ribbon cable that is fused with it.
Replacing the GPU is very difficult. I would start with replacing the screen.
If that fails, return the screen. Then it must be motherboard related. But so far, I suspect the screen…
Punteggio 2
2 Commenti:
I can't just order a screen and then return it after, if it doesn't solve the problem. It's because where I live. I wish I can do that, even finding people who can lend me steam deck oled for troubleshoot is very hard. What I can do now is just asking about people's experience who encounter the same problem.
da Condividi
Okay, that makes it somewhat harder indeed. It's very hard to say if it's the screen for like 100% sure... I think it is the screen as it does worked in dock mode. But, I cannot guarantee it... Testing would be the best solution. How much does a new steam deck cost and how much does the screen cost? If the difference is small, I would get yourself a new Steam Deck and will not gamble with it. I think this is the safest option here.
da Condividi
Aggiungi la tua risposta
Onyx sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 29
Tutti i Tempi: 117
