Why long light not working
Patina long light not working why
Questa è una buona domanda?
When you say "..long light..." do you mean the high beam headlight?
If you do, have you checked if the headlight bulb is OK. It is a twin filament bulb i.e. one filament is for the low beam and the other for the high beam. When the high beam is turned on, both filaments are lit.
If the headlight bulb is OK does the high beam indicator light in the instrument panel, turn on when you operate the headlight dimmer switch to turn on the high beam headlight?
If it does then if the headlight bulb is OK it could be a wiring problem between the headlight dimmer switch and the headlight.
If it doesn't turn on it could be a faulty headlight dimmer switch.
Here's the wiring diagram that may help if it's a wiring problem.
(click on image)
Ultime 24 ore: 2
Ultimi 7 giorni: 3
Ultimi 30 giorni: 11
Tutti i Tempi: 44
