Salta al contenuto principale
Guide di riparazione e assistenza per la prima generazione di Porsche 911 raffreddate ad acqua: la serie 996.
Stop light not working
Right stop light not working, my 996 has aftermarket LED tail lights, I replaced both unit door new ones and the problem continues..
All other lights work fine (turn signals, hazards, reverse, night lights)
Questa è una buona domanda?
Punteggio 0
1 Commento
Thank you! I checked for 12v on tje 4 pin at the light with the brake pedal pressed without any luck… will have to trace that 13 connection… doesn’t look like a fun task, specially with no electric experience…
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @diegoestra71869
Check if there's 12V DC on pin 4 of the connector that the right tail light assembly cable plugs into, when the brake pedal is operated.
If there isn't and since the left side brake light is working, there may be a wiring problem between pin 4 on the connector and the multiple wiring connection point # 13.
Unfortunately I don't know where that is located. You may have to trace the harness wiring back from the right side (or the left side) tail light assembly.
Here's an image of the relevant part of the wiring diagram that may help.
Immagine
(click on image)
Punteggio 2
Aggiungi la tua risposta
Diego Estrada sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 20
Tutti i Tempi: 67
