Salta al contenuto principale
La Volkswagen Beetle è stata un'auto compatta prodotta dalla casa automobilistica tedesca Volkswagen. È stata introdotta nel 2011 come successore della New Beetle.
Engine light is staying on
Engine light won't go off how do I get it off?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @donnaspeight
What year is the vehicle?
The check engine light is on because it's warning you that there's a problem with the engine or the transmission.
The only way to get rid of the light is to get the problem fixed. Once the problem is fixed the light will be off.
The easiest way to find out what's wrong is to get the vehicle's OBDII port scanned with an appropriate scantool to see what DTC codes Index 1, Index 2 have been logged by the ECM (Engine Control Module).
The code will tell you what the problem is.
Major auto parts retail stores in the USA will do this for free apparently.
Punteggio 1
Aggiungi la tua risposta
Donna Speight sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 26
Tutti i Tempi: 69
