Salta al contenuto principale
Pubblicata a novembre 1998, identificabile dal numero di modello HKT-3020.
What is going on here?
Hi, I recently install the retro gem for my Dreamcast and when I boot the system it doesn't show the boot animation for the system only when its completed I went to debug menu and have hearts on all my installs as well as updated the firmware. I tried this on two TVs and it does the same thing. I have a Gamecube with a plug-in mini-HD to HD and it does something similar I used the same cable from that.
Questa è una buona domanda?
Punteggio 0
8 Commenti
Hi!
Is it possible to upload some pictures regarding the issue you are facing?
Aggiungere immagini ad una domanda
Thank you.
da
Can I upload video? pictures won't help
da
Yes you can!
Using Media
Thank you
da
Hi, I upload the videos in the first video it's the gamecube with the hdmi plug-in, the second one is the gamecube with S-video, and the third one is the dreamcast with the mini-HD to HD. I used the mini-HD to HD from the plug-in I couldn't get the av footage for the dreamcast cause I think I messed something up ....again, but it does the same thing as the gamecube plug-in. I hope its just the mini-HD to HD cable that's causing this. It's the basic edition of pixelfx mod
da
Okay, replacing the cable you can try indeed. It does not really look like a hardware issue in the first 2 pictures. More firmware related. Which firmware has been installed? Thanks!
da
Mostra 3 altri commenti
Aggiungi un commento
1 Risposta
Soluzione prescelta
@dan0 Hi, I went on the retro gem discord and I was told that the delay in video is normal because the retro gem is booting.
Punteggio 0
3 Commenti:
Alright. Then it is normal behaviour. Thanks for sharing!
da
Sorry for the delay thank you
da
No problem at all! Have a great day :)!
da
Aggiungi la tua risposta
Christopher D sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 26
Tutti i Tempi: 176
