Salta al contenuto principale
Guide di riparazione e assistenza per il tuo televisore Toshiba.
Old king Horizontal line problem
Immagine
Secret cards name is lnv55L96c made by Samsung.
Immagine
there is a secret card under metal sheaild***
Toshiba 55sv685d
What ist the problem? I love this tv. Can you help me please?
bDys23xvRHKQVJfZ.full (4000×3000) https://share.google/YsSsvDXFM1pmCy4sN
Update (05/25/26)
Immagine
Immagine
Immagine
Immagine
Immagine
Immagine
Questa è una buona domanda?
Punteggio 0
2 Commenti
@fatihemre that will depend what it looks like. Horizontal lines are usually caused by issues with the panel. We will see what your TV shows you. Post a picture of that with your question. That way we can see what you see Aggiungere immagini ad una domanda
da
Aggiungi un commento
1 Risposta
Risposta più utile
@fatihemre those lines can be caused by the main board as well as bad LVDS cables. Worst case is a bad panel. I would remove the back cover and check the flat ribbon cables for any tear and corrosion. You can always clean the ends of the cables with a pencil eraser. If that does not help, you could try a main board, provided you can find one for a decent price. Once you have the back cover off post some good pictures of the boards and the interconnect cables etc. That way we can hopefully assist you with that further.
Punteggio 2
5 Commenti:
Where should I focus on?
da
@fatihemre the main board is the big green one. The smaller green board is your T-Con board and the large brown one is the power board. For now I would focus on the large green board
da
@oldturkey03 info: secret cards name is INV55L96C, made by Samsung. I dont know what its job.
da
@fatihemre that is your LED controller. It controls the LED baklight strips.
da
info: when tv is cold first start there are no horizontal lines, after 2 minutes I hear A low, high-pitched sound and horizontal lines appear.
da
Aggiungi la tua risposta
Fatih81 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 21
Tutti i Tempi: 178
