Display or CPU or GPU problem
I use a hp VICTUS 16 gaming laptop last year I have faced an issue which is the laptops display is getting turned on and off very fastly like it's blinking along with keyboard lights after some time it completely goes off whole laptop i can send you video also
Questa è una buona domanda?
Hi @spamx
The video you sent is not working, (shows 0:00 / 0:00 and not the time length of the video e.g. 0:00 / 0:12 for a 12 second video etc) you may have to upload it again.
Does the laptop do this when the charger is connected or when starting the OS in safe mode?
da jayeff Condividi
I got a laptop for repair hp Omen 16 which has exactly the same issue...this issue occurs due to faulty power component which does not regulate the power and the supply to gpu and cpu is not properly passing through which cause the laptop shutdown or blackout.. no display coming on screen though the fan is running ..even sometimes the light on screen is flashing ...keypad lights are also flashing sometime..
I will find out the issue and post it in few days
da chiragchh Condividi
@chiragchh and is there anything you want me to do like any diagnosis or anything and I'm waiting for you to find the issue and
da spam.x Condividi
I’m having the exact same issue with the exact same laptop, the victus 16-s0075nr. Mine is also out of warranty and I took it to micro center and they gave me a $700 quote to replace the screen, bezel, and ribbon cable that connects the screen to the motherboard. I bought the laptop for $700 so it’s clearly not worth that repair, especially because I don’t feel like that will fix it. I don’t believe it’s a short because it doesn’t happen consistently when I shake the laptop around (like I’d expect a short to do).
Edit: Take a look at this Reddit post: https://www.reddit.com/r/HPVictus/s/uiif...
Looks like the issue is caused by the Hall effect sensor. I unplugged mine and it fixed it
da Caleb Foster Condividi
@chiragchh did you find the issue of hp omen 16 which has the faulty power component which does not regulate and supply to gpu and cpu
da spam.x Condividi
