Salta al contenuto principale
Il DualShock 4 CUH-ZCT2 è stato annunciato nel 2016 per sostituire il controller CUH-ZCT1 rilasciato nel 2013. Questo controller è simile al modello precedente.
Is my PS4 Controller Fake or Original?
Hello Everyone.I have a question.
I have a DualShock 4 Controller with Model CUH-ZCT2.Its working perfectly.I also have another controller that is copy and i can feel the pretty much difference between my copy controller and original(assumed) controller.I brought my PS4 2nd hand in good condition.That dude told me that Black controller is copy and second one that have a custom elden ring shell is original.
1:This controller performs very well and doesnt have any input delay like my copy controller.I played GTA V and other games to compare them and Original(assumed) Elden ring controller performed very well.
2.This controller joysticks also have firm resistance and it is very accurate and aiming is easy in games.its buttons are also good.And joysticks buttons L3 R3 also can be clicked and have a damp and different sound than my copy controller.
3.Unlike other controllers this controller has a sticker on which 1000MAh is written.Im not sure if there is any model that has written 1000mah battery as most of has written 800mah.I also opened it and battery is original 1000mah .
4.Its joysticks can also pop out(not out of shell) and snap back in.I have tried this on my copy controller but it has fixed joysticks that cannot pop out.
5.Im attaching pictures and videos of every single part of my controller.I have also attached videos with button sounds.
So please someone answer me if my controller is original or not.By my Point of View it seems totally original...
@dan0
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi!
Controller seems to be genuine! Only the front plate is changed or it is a sticker.
Can you also show how the battery looks like?
For now it seems genuine!
Punteggio 1
13 Commenti:
Thanks for ur kind reply.
Hmm Ok
Battery is in gray color original as you showed in pics.
The main confusion is back sticker.Please tell me if this sticker is original as 1000mA is written on it.Please explain me if this is legit.A1 is also written after 1000mA.I asked chatgpt and it told me that A1 means this controller has JDM 040 or higher.
2
And another question that is there any motherboard model that has a blue switch on it?
da
@Dan0
Yeah the front plate(shell) is custom elden ring.I guess old owner changed this
da
Nope. Sticker should say: “800mAh”.
So either he put on a random sticker, or the backside isn’t genuine.
The motherboards I know off, do NOT have a blue switch/button on the motherboard. For every one of them, it’s white.
Apart from above, it does seem genuine. It’s still possible that he replaced the switch/button for another one.
Answer your 2nd comment: Okay, so then you do know that the shell isn’t genuine same for the backside sticker.
I would either use the controller and live with it, or get yourself a new one from a known reseller that sells only genuine controllers/items etc.
da
@dan0 Ok Thanks!
da
@dan0 I opened it and its motherboard switch is blue.But if motherboard is fake then how joysticks can pop out and back in just like original controllers
da
Mostra 8 altri commenti
Aggiungi la tua risposta
Sufyan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 40
Ultimi 30 giorni: 146
Tutti i Tempi: 395
