Salta al contenuto principale
Informazioni su riparazione, smontaggio e soluzione problemi per Steam Deck OLED, un aggiornamento del 2023 della popolare console videogame portatile prodotta da Valve. Rilasciata il 16 novembre 2023. Identificata dal numero di modello 1030.
Left trackpad occasionally not working
Is anyone experiencing the same issue where the left trackpad becomes unresponsive and can be fixed by turning it off and on again?
I can’t pinpoint the cause because it’s very unpredictable. Sometimes, I can use the trackpad normally, and the next second, it suddenly stops working.
I’ve already tried factory resetting the device, but the problem persists. I’ve also tried updating to the beta version, but that didn’t help either.
Interestingly, the trackpad always worked when I was in BIOS mode, so I’m assuming it’s a software issue.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi!
Sound like a software issue for me too.
Did you tried to contact Steam support? Maybe they have some tricks in mind.
Is there still warranty on it?
Punteggio 1
Aggiungi la tua risposta
K A sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 21
Tutti i Tempi: 135
