Salta al contenuto principale
Il minivan di quinta generazione ha debuttato al North American International Auto Show del 2007 con uno stile esterno disegnato da Ralph Gilles.
Air conditioner not.working
After replacing tipm my air conditioner is no longer working. Replace relay, its fully.charged but.still doesnt work
Questa è una buona domanda?
Punteggio 0
4 Commenti:
This question was migrated from https://meta.ifixit.com/Answers.
da
Hi @kathy21141
As you mentioned replacing the tipm, I assume that the air con is in a motor vehicle.
If this is correct, what is the make, model and year of the vehicle?
Moderator.
da
@jayeff 2019 dodge grand caravan
da
@kathy21141
Does the blower motor work when you turn on the air con?
Can you hear the compressor clutch operate when you turn on the air con - with the engine idling there should be a clunk sound as an electric clutch engages the compressor pulley so that the serpentine belt turns the compressor?
da
Aggiungi un commento
1 Risposta
If the A/C stopped working right after replacing the TIPM, the issue is likely related to power, programming, or communication rather than the refrigerant charge itself.
A few things to check:
  • Make sure the new TIPM is the correct part number and properly programmed for the vehicle
  • Check all A/C-related fuses again, even if they look good visually
  • Verify the compressor clutch is getting power when the A/C is turned on
  • Scan for trouble codes because some TIPM replacements can trigger communication or sensor issues
  • Check the pressure switch and A/C compressor connector for loose wiring during the repair
  • If the radiator fan is not coming on, the A/C may also stay disabled
Since you already replaced the relay and confirmed the system is charged, I would focus on electrical diagnosis next. A multimeter or scan tool will help much more than replacing more parts randomly.
Punteggio 0
Aggiungi la tua risposta
Kathy sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 42
Tutti i Tempi: 192
