Salta al contenuto principale
Informazioni di riparazione per il frigorifero Samsung RF28R7201**—un frigorifero a quattro porte a profondità standard del 2019 con finitura in acciaio inossidabile o acciaio inossidabile nero.
Need help identifying a part
Brand: Samsung
Model Number: RF28R7201SG
Main Symptom: Need help to identify a part
What happens & when: NA
Error Code (if any): NA
Parts or tests already tried: NA
Photos / video link: SamsungIceMakerPart - Google Drive
Trying to identify this part. It is a bit melted from when I used a heat gun to melt some ice ('I know, bad idea). This is the plastic piece that protects the Styrofoam surrounding the freezing element in the Ice Master ice maker. It goes around the element and the foam. The auger assembly actually slides into this and the fan mates up with the bottom.
Questa è una buona domanda?
Punteggio 0
7 Commenti:
Did you try plugging in fridge model into Samsungparts.com's site? Samsung may have spare parts otherwise other online distributors may carry parts.
da
Yeah, ive looked at a couple of sites. Not really finding the part in the parts diagrams and rolling through the parts, not seeing a pic. I figure if someone knows the part name i'd have better luck.
da
any suggestions on where to find a non blurry parts diagram?
da
@paultippit
From your description is it a part of the auger case assembly?
da
no, I bought the auger case assembly to resolve a fan issue. It IS the plastic piece that the auger assembly slides into and it protects the styrofoam insulation around the element
da
Mostra 2 altri commenti
Aggiungi un commento
1 Risposta
Immagine
Immagine
Immagine
Apparently it is called the 'Fixer Fan Duct' da61-08180. It also seems to be out of stock everywhere or unavailable.
Punteggio 0
Aggiungi la tua risposta
Paul Tippit sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 3
Ultimi 30 giorni: 15
Tutti i Tempi: 136
