Salta al contenuto principale
Il controller PS4 modello CUH-ZCT1. Rilasciato nel Novembre 2013 dalla Sony Computer Entertainment, la sostituzione della batteria da 3.7V di questo "six-axis" non è una riparazione complicata (N.B.: La guida di smontaggio NON è per questo modello)
Can this component be replaced?
So when I was trying to change the analog sticks on my controller I accidently knocked off a component fortunately I have a few motherboards with that component can it be replaced?
Immagine
Immagine
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi!
Yes it can, but requires soldering.
I think it’s a cap.
But since you got the same component on another motherboard, you can just replace it!
Please let us know how that goes!
Punteggio 1
6 Commenti:
As long as the pads haven’t been pulled off
da
Do they look pulled off?
da
Hard to see.. can you upload a closer/sharper picture? If the pads are ripped off, you need to repair the solder pad there..
da
@christophe89153 try to apply solder to the contacts; if they stick then you're fine & if they don't then you've ripped the pads off. fortunately it's not such a hard fix judging from the pics but it's a little hard to explain
anyway, try to apply solder to the pads and see if they stick first, that'll help a lot.
da
Update I put solder on the pads and it looks like it's sticking I've uploaded a photo
da
Mostra 1 altri commenti
Aggiungi la tua risposta
Christopher D sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 16
Tutti i Tempi: 107
