Guida alla riparazione e informazioni sul congelatore a pozzetto Admiral RFCA150AAW, un modello del 1998 con sistema di sbrinamento manuale e accesso tramite sportello.
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
3 Commenti:
Locate the coils and clean them first; sometimes, if dust or debris gets on them, they can't dissipate heat efficiently. Also, is the fan spinning at all, or do you feel the cold air moving around the machine?
There is no fan inside the freezer and the evaporator coils are in the walls of the freezer cabinet i.e. static cooling method is used. This method is commonly used in chest freezers
da someperson
Hi @alvinmayers,
Does the compressor feel warm/hot to the touch?
What is the actual temperature inside the freezer compartment?
da jayeff
@somerandomguy_1
Cheers
da jayeff
