Computer box not recieving 12v
My clio 2 has lost power on coil connectors now it doesnt start its just quite
Questa è una buona domanda?
Here are the wiring diagrams for a Clio II, that might help. Hopefully they are applicable to your model
Thanks i see the diagrams
Ultime 24 ore: 0
Ultimi 7 giorni: 11
Ultimi 30 giorni: 35
Tutti i Tempi: 224
9 Commenti
Hi @bonganisib42530
Does the engine crank when you turn on the ignition key?
Have you checked that the battery is OK?
da jayeff Condividi
It used to crank before i thought its the crank sensor but only to find out after diagnosing it had a code that reads +after relay supply
da bongani sibanyoni Condividi
@bonganisib42530
Did you check if relay #1 Ignition main circuits relay 1 in the instrument panel fuse box is operating (click sound) when the ignition key is turned to start.
Also check relays #5 Starter motor relay, #9 Ignition main circuits relay 2, fuses F13, F14, F18, F22 & F24 in the engine bay fuse box are all OK.
All the above need to be OK when cranking and having the engine turn on
da jayeff Condividi
I dont know which relay is the ignition relay there are 3 of the brown ones 20A then there are 2 pink 40A then purple 50A but all the fuses are ok i once tested a bridge that i think is the ignition relay and it blew the ignition fuse thats maybe when i started realizing that it may be the ignition relay
@bonganisib42530
Here's a link to the fuse box diagrams for the 2006-2012 Clio models (you didn't say which year your vehicle is) that shows the location of the relays and fuses in the 3 fuse boxes i.e. main fuses box and power supply box in engine compartment and fuse box in instrument panel in the passenger compartment.
da jayeff Condividi
Mostra 4 altri commenti
