Salta al contenuto principale
Il controller wireless Sony DualSense Edge (CFI-ZCP1) è stato lanciato a gennaio 2023. È dotato di moduli delle levette sostituibili e altri miglioramenti rispetto al DualSense.
Fn button stuck in pressed state
Pad just stuck in profile select mode due to always pressed right Fn button, I swapped the modules and even bought new ones, but it didn't help.
Immagine
also i have this: 0300e0274c050000f20d000000016800,*,a:b0,b:b1,back:b4,dpdown:h0.4,dpleft:h0.8,dpright:h0.2,dpup:h0.1,guide:b5,leftshoulder:b9,leftstick:b7,lefttrigger:a4,leftx:a0,lefty:a1,rightshoulder:b10,rightstick:b8,righttrigger:a5,rightx:a2,righty:a3,start:b6,x:b2,y:b3,touchpad:b11,misc1:b12,paddle1:b16,paddle2:b15,paddle3:b14,paddle4:b13,crc:27e0,platform:macOS,
So the main question is how to understand what exactly the problem is next, and what to change, since this is definitely not a problem with the stick module.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi!
Then it's most likely something on the board.
Try to clean the connector and inspect if there are any bent pins.
If it's bent, try to fix it.
In the worst case, you need to replace the port or replace the board.
Guide: Sostituzione scheda madre DualSense Edge
If possible, can you sent us some pictures regarding the joystick port?
Thanks!
Punteggio 1
2 Commenti:
Actually, it sat for almost a year after I bought it. I simply forgot about it. It only showed up after 4-5 days of use, and I didn't have time to replace it. I cleaned the connectors with rubbing alcohol, but everything was still the same. I'll post a photo later, I'm not at home right now. I also thought it might be the motherboard, since there's nothing else there that could cause this. And thanks for the reply! I'll send photo as soon as I get home)
da
Thank you! That is most likely it yes. Nothing else should be able to cause this, so far I'm aware of.
Please let us know when you have an update :). Thanks!
da
Aggiungi la tua risposta
Granchik sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 17
Ultimi 30 giorni: 91
Tutti i Tempi: 545
