Salta al contenuto principale
Il GameCube è la quarta console videogame di Nintendo. La riparazione è semplice e richiede solo strumenti di riparazione comuni.
Disc board fails to spin disc
I've got a gamecube with an interesting problem. I have another cube that is known working and I've done part by part swaps (motherboard, disc motor, hinge switch) to narrow down my issue. Something on my disc drive board is wrong and it will not spin the disc. Changing the motor to my known working cube proves the motor isn't the problem. I even swapped the good motor to see if that will work, which it didn't. I have a cheap multimeter and the caps are taking a charge and discharging as normal. A reflow of the hinge connector has not fixed my issue. I'm at my wits end and about to call it a lost cause.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi!
Pretty sure that the caps failed on the disc drive board…
I would replace them and see what happens.
You can find the kit here: https://console5.com/store/nintendo-game...
Please let us know how it goes!
Punteggio 1
Aggiungi la tua risposta
D2 the Hobbiest sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 18
Tutti i Tempi: 120
