Salta al contenuto principale
Accessorio Bluetooth che combina uno strumento di cattura per l'app "Pokémon GO" e un tracker del sonno per l'app "Pokémon Sleep"
Pokemon Go+ will not power on
My Pokémon Go + will no longer power on or take a charge.I recently had some water spill on it. It didn’t seem like a significant amount, but I’m not sure if that damaged the catcher or if I potentially overcharged it by leaving it on my car phone charger. I’ve tried to replace the battery but had no success. Any idea on what to do next?
Update (03/07/26)
I can check for corrosion but unsure how to examine the motherboard
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi!
Please check the motherboard for corossion. Pretty sure it’s motherboard related…
If there is corossion on it, please clean it completely with isopropyl alcohol.
If possible, can you share some pictures with us?
Thanks!
Punteggio 1
1 Commento:
Is it possible to remove the motherboard and check that side as well. Please clean everything with isopropyl alcohol and also the connectors. Thanks!
da
Aggiungi la tua risposta
Jay Sing sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 38
Tutti i Tempi: 323
