Salta al contenuto principale
Informazioni di riparazione per la sesta generazione di Nissan Altima, riguardanti i modelli dal 2019 a oggi.
How do I replace a thermostat?
Where is the thermostat located and how do I replace it?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @clinton38566
What is the engine size and which thermostat do you need to replace?
Reason for asking is the 2.5L engine has 2 thermostats whereas the 2.0L engine only has 1.
Punteggio 2
3 Commenti:
It's the 2.5L. I believe its the main engine thermostat, since its the one that works with the heater core. I currently don't have heat in the car and was advised that this is most likely the reason.
da
@clinton38566
The video in the blue link above shows a thermostat in the engine block being replaced at 3:26 minutes
da
@jayeff Thank you. I'll check it out.
da
Aggiungi la tua risposta
Clinton sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 11
Ultimi 30 giorni: 48
Tutti i Tempi: 479
