Salta al contenuto principale
Guide di riparazione, smontaggio e soluzione problemi per il mouse wireless portatile Logitech MX Anywhere 3S. Ăˆ uscito a dicembre 2023 e si chiama con i numeri di parte 910-006925, 910-006926, 910-006927 o 910-006928, a seconda del colore. Successore dell'MX Anywhere 3.
Left button not working
The left button intermittently works and has been getting progressively worse over time. Should I follow the disassembly steps as described to replace the battery and try and clean the buttons with compressed air?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Risposta piĂ¹ utile
Hi @mcfb, if the Logitech MX Anywhere 3S is still under warranty, I recommend sending it in for repair. Based on my experience, once the warranty has expired the usual fix is replacing the microswitch. The part commonly used is an Omron D2FC-F-7N or similar, which requires desoldering the old switch and soldering in the new one.
Punteggio 3
4 Commenti:
Thanks @augustine, I'm chasing warranty - I'll see how that goes first. Thanks for the help.
da Condividi
Is this a common problem with this model?
da Condividi
I have the same problem with left click, i'm going to try to repair the button. (Tape was not the issue, it was 100% the button malfunctioning)
da Condividi
This can't be true, those switches are substantially larger than the ones present in the MX Anywhere 3S
da Condividi
Aggiungi la tua risposta
mcfb sarĂ  eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 33
Ultimi 30 giorni: 186
Tutti i Tempi: 1,246
