Salta al contenuto principale
L'MSI GF63 Thin è un portatile da gaming caratterizzato da un display con cornice sottile, processori potenti e schede grafiche dedicate. È progettato per essere portatile e leggero, il che lo rende un'ottima scelta per i gamer in movimento.
Power button IC part identification
I have an MSI GF63 Thin Gaming Laptop, 15.6" FHD 144Hz, Intel i5-11400H, RTX 3050, 16GB RAM, 512GB NVMe SSD. The laptop won't power on at all.
I live in South Africa and my local authorized MSI Repair Center was unable to help me (they quoted a whole board swap, which was more than the price of the laptop), and MSI Forums haven't been any help, but I had a private technician diagnose the problem. The part that failed is the IC near the power button, and I need to know the specs for the part so that I can buy a replacement. The laptop is out of warranty so I want to do the repair myself. I cannot find any serial number or manufacturer for the IC in question, all I know is that it is a 6-pin, 12V IC. Can anyone provide me with information on the type of IC needed, manufacturer/serial number and specs? I would be very appreciative for any assistance or advice! An image of the part in question is attached if needed, the part at MH1 Q5 on the board.
Thanks in advance!
Immagine
Questa è una buona domanda?
Punteggio 1
1 Commento
Hi @maverickpearson
What is the model number of the motherboard (printed on the board) e.g. MS-16R31, MS-16R41 etc?
If the schematics for the board can be found they usually have the component type (or model) number shown next to the component in the schematic.
You won't need to find the boardview file as well (usually harder to find or not available) as the component's board ID i.e. MH1 Q5 (same as component's ID in schematic), is shown on the board unlike some of the other components shown in the image you posted
da Condividi
Aggiungi un commento
1 Risposta
Soluzione prescelta
@maverickpearson having gone through multiple boardviews for a MSI GF63 Thin, the one for the MS-16R51 motherboard shows all of your components as well as the right reference designator, Q5. Now, that schematic is not available but the same component and circuit is used on the MS-16R11 (as well as many other) motherboard. The component you need is a NN-DMN65D8LDW-7 MOSFET in a SOT363-6 package. It is available at places like this and many others. Here is the DMN65D8LDW datasheet.
Punteggio 2
1 Commento:
Thanks very much for the assistance with this!
da Condividi
Aggiungi la tua risposta
Maverick Pearson sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 44
Tutti i Tempi: 377
