Salta al contenuto principale
Il Lenovo ThinkPad 13 Gen 2 è un portatile dal prezzo accessibile, orientato al business e rilasciato all'inizio del 2017, dotato degli ultimi processori Intel dell'epoca, che spaziano dai Celeron di fascia bassa ai chip Core i7 di fascia alta.
How would I add more RAM?
I have this laptop and would like to add more RAM to it but don't want to damage my laptop, how do I add extra RAM if possible?
Questa è una buona domanda?
Punteggio 0
1 Commento
It might be better if you consult in a professional to fix your problem. The cost might be low because of quick work. It will likely take 10 minutes to finish
da Condividi
Aggiungi un commento
1 Risposta
Risposta più utile
Hi!
Unfortunately that is not possible. The RAM is soldered on the motherboard. Unless you have some serious soldering skills.
The SSD and WiFi are replaceable tho.
Guide: 🛠️ Lenovo ThinkPad L13 Gen 2 - disassembly and upgrade options
Please let me know if you have any further questions!
Punteggio 4
2 Commenti:
I have the Lenovo ThinkPad 13 gen 2 20J2. I have disassembled it many times and have come to learn that it has 2 SODIMM memory slots that can be seen when removing the bottom cover. I'm not sure if every model or variation has modular memory, but mine does.
da Condividi
Hi!
Usually this is not the case for this model. Can you share some pictures with us? Also regarding the motherboard model?
Thank you!
da Condividi
Aggiungi la tua risposta
Albert Einstein sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 24
Ultimi 30 giorni: 77
Tutti i Tempi: 692
