Salta al contenuto principale
Il portatile HP Probook 4330s è dotato di processore Intel Core i7/i5/i3 di seconda generazione o Intel Celeron B810. L'HP Probook 4330s è equipaggiato con un display HD da 13,3”, chipset Mobile Intel® HM65 Express, Bluetooth 3.0, Wi-Fi, quattro porte USB 2.0, una porta VGA, una porta HDMI e una webcam HD.
How to fix boot error problem
Video to solve this problem
Questa è una buona domanda?
Punteggio 0
1 Commento
Hi @aashishnana67
You have asked the same question 3 times now and had responses to the first 2 questions asking for more information so relevant answers could be provided.
1st question
2nd question
You have not responded to their requests for more information.
Please stop asking the same question and respond with more information as to what the exact problem is.
Moderator.
da Condividi
Aggiungi un commento
1 Risposta
Risposta più utile
A boot error on an HP ProBook 4530s usually comes from incorrect BIOS settings, a failing drive, or corrupted boot files. First, enter BIOS (press F10 on startup) and ensure the hard drive is detected and set as the first boot device. If detected, run HP Diagnostics (F2) to check HDD health. If the drive fails tests, replace it. If the drive passes, boot from a Windows installation USB, choose Repair your PC, then run Startup Repair. You can also use Command Prompt to run bootrec /fixmbr, /fixboot, and /rebuildbcd. Update BIOS if needed. If errors persist, reinstall Windows.
Punteggio 1
Aggiungi la tua risposta
Aashishnana 67 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 9
Ultimi 30 giorni: 32
Tutti i Tempi: 181
