Salta al contenuto principale
Modello A1419 / EMC 3070 / Metà 2017 / processori Core i5 3.4, 3.5 o 3.8 GHz o Core i7 Kaby Lake 4.2 GHz (id ImAC18,3) / Retina 5k display. Fai riferimento alle guide del modello più vecchio dell'iMac 27" Retina 5K display (fine 2014 & 2015), dato che il sistema è molto simile.
OEM hard drive replacement
What is the Kit for an OEM hard drive replacement
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Is this what you are looking for? SATA HDD to SSD upgrade or PCIe/NVMe Blade SSD upgrade
And here's the two guides:
The HDD drive swap-out is the easiest to do, but the Blade SSD offers better performance.
Do keep in mind if you have a Fusion Drive you have both drives present! And you will need to disable the Fusion Caching SSD (Blade Drive) otherwise you'll encounter issues as it wants to join the fun which you don't want!
The easiest way to disable it is once you have the system running open Disk Utility and make sure you select show all volumes so the hidden Cache drive can be selected and reformat it deleting it fully. Is mostly a useless drive as it's too small to effectively hold the OS.
Immagine Upgrade the storage and improve boot time and read/write speed in your iMac Intel 27" Late 2012-2019 with this SSD upgrade kit.
Prodotto
iMac Intel 27" (Late 2012-2019) SSD Upgrade Kit
$146.99
Immagine Upgrade your iMac with a new SSD to dramatically speed up your machine.
Prodotto
iMac Intel 27" (Mid 2017-2019) SSD Blade Upgrade Bundle
$249.99
Punteggio 0
Aggiungi la tua risposta
Core Solutions sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 9
Tutti i Tempi: 128
