Projectiondesign F35 Problem doing firmware update, please help.
Please help.
Projectiondesign F35 AS3D Vizsim 1080
When attempting to do a firmware update it comes up with the message detected firmware and a few seconds, prompts to remove the USB after reading its contents reboots after that, but nothing is installed.
Current firmware is 010-0003-09
Trying to update to 010-0003-25 downloaded from Barco website.
Have followed instructions in manual on Barco website.
Memory stick has USB FAT-file system and the unzipped release.tar on the root of the USB memory stick.
Have downloaded the firmware twice and tried two different USB memory sticks.
Am I missing a step not mentioned in the manual?
Are there any stupid things I might be doing wrong without releasing it?
Thanks.
Questa è una buona domanda?
Hi @dovercat
Did you select the eject function before removing the USB stick from the PC or did you just unplug it?
da jayeff
Thank you for checking. Yes - I did click eject before removing the USB stick from the laptop.
da Dovercat
@dovercat
I couldn't find any but are there any earlier firmware updates available that you could try i.e. between current 010-0003-09 and the one you trying to install?
Just wondering if a progressive firmware update is required rather than missing a few and jumping to the latest one available
da jayeff
