Salta al contenuto principale
Kenmore è un noto marchio di elettrodomestici comunemente venduto da Sears, ma Sears non produce personalmente nessuno dei suoi apparecchi. Si affida invece a produttori esterni per realizzarli. I frigoriferi Kenmore sono prodotti da diversi fabbricanti, tra cui LG, Electrolux, GE e Whirlpool.
Door bottom support broken
Refrigerator door is misaligned. Too low, scrapes the bottom of inside of frig as you try to close. Tried a taller leveling screw but bottom of frig door just collapses and door will not get back to original location. Is the bottom of the door that supports the leveling screw replaceable or fixable. Thx
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Hi @bdwest23242
What is the model number of the refrigerator?
da
253.67879509
da
Aggiungi un commento
1 Risposta
Hi @bdwest23242
If the lower door scrapes the inside of the compartment, it may be a loose lower hinge bracket, worn hinge pin or spacer.
Here's a video that shows how to replace the hinge pin that may help.
It shows how to gain access so that you can check if the bracket (bent/loose?), the hinge pin (worn?) and spacer are all OK or not.
If replacements are required, the part numbers are as follows. Search online for the part number only to find suppliers that suit you best.
lower hinge pin = 240516502
spacer = 240311303
lower hinge bracket = 240314011
Note: The refrigerator is a Frigidaire model, made for Kenmore as it is made entirely from Frigidaire parts. That's why parts results show Frigidaire name. Kenmore doesn't make appliances, they rebadge/made to order other makes of appliances e.g. LG, Frigidaire, Whirlpool etc
Immagine Connects the refrigerator door to the lower hinge, allowing it to pivot.
Prodotto
Electrolux Refrigerator Lower Hinge Pin - 240516502
$53.99
Immagine Supports the refrigerator door at the lower hinge point.
Prodotto
Electrolux Bracket-Lower Hinge - 240314011
$57.99
Immagine Nylon washer for refrigerator hinge, sold individually.
Prodotto
240311303 - Frigidaire Refrigerator Hinge Nylon Washer
$18.99
Punteggio 0
2 Commenti:
Unfortunately lower bracket all good. So is pin and spacer. It’s the door itself that has an issue. Caved in and can no longer support the pin. Thx for the reply. I’m assuming I would have to change door. Correct ?
da
@bdwest23242
Looks like it will have to be as they're a sealed unit i.e. filled with foam insulation
According to this parts supplier there are 3 doors compatible with the model
Part # 241623407, 240438617 & 240438619 click on Door parts diagram, expand the diagram to see part #15 in the diagram.
da
Aggiungi la tua risposta
Bdwest sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 16
Tutti i Tempi: 180
