Salta al contenuto principale
Informazioni di riparazione e guide allo smontaggio per le lavatrici a carica frontale LG.
Help Finding Part For LG Washer
Hi! I need a door latch assembly for my LG washer model WM3470CM but I can't find the part that matches up to this model. Can anyone point me to one that will work so that I can replace it? Thanks in advance!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @wearingthepants,
Try using an EBF61315802 (supplier examples only)
Here's a video that shows how to replace it.
Update (09/17/25)
Hi @wearingthepants
The part number is usually found on the part itself if you wish to verify by checking the part number on the original door lock in the washer, that it is the correct one, before ordering it.
Here's an image that shows where to look
Immagine
(click on image)
Immagine Keeps your washer door locked during wash and spin cycles.
Prodotto
EBF61315802 - LG Washing Machine Switch Assembly
$122.99
Punteggio 2
1 Commento:
Oh, thank you so much, this is very helpful!
da
Aggiungi la tua risposta
Wearingthepants sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 15
Tutti i Tempi: 206
