Salta al contenuto principale
Il Samsung Galaxy S21 FE (Fan Edition) è una variante del modello S21 ed è stato rilasciato l'11 gennaio 2022. Il telefono presenta alcune differenze rispetto al modello S21 principale, che lo rendono leggermente più economico.
Rear Camera (main camera / middle)
Has anyone come across this issue. We have been repairing phones for 8 years and this is a first for us.
Galaxy S21 FE 5G (SM-G990E) We replaced the main camera as exposed when back lens cracked and was damaged.
We have replaced 3 cameras and none work. they are Samsung Service centre parts
  • Camera app, says Camera Failed and closes down
  • *#0*# test menu won't load the camera test
  • Samsung Members app test says send to Samsung service centre.
We have checked the serial number on the original camera is the same number on the replacement. As some charging ports the U / B model is important for function. But Original and New same serial on the part.
the Samsung Self Repair Assistant App, is not available in Australia. We have downloaded the Apk file from US version. and won't run the calibration.
Have I been extremely unlucky and just had 3 faulty cameras or is there some new software issue stopping it from functioning.
  • Safe mode I have tried
  • all software is up to date
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi @james17114
Check the status of the LDI (liquid damage indicator) to see if any water/liquid has entered the phone through the cracked camera lens and has caused any damage.
If it is OK or even if not, the service manual will help to find out what's wrong.
I couldn't find a free download online (you may have better luck) but here's a link to a download for a model variant that is not too expensive.
The manual has troubleshooting flowcharts for most of the functions of the phone as well as board layout diagrams. Use the search function of your browser to find the location of the components mentioned in the relevant flowchart. You may have to zoom in a lot to see them ;-)
I don't know about this particular manual, but most also have a comprehensive parts list as well i.e. includes board components e.g. capacitors, resistors, inductors etc as well.
If there is a parts list and if you find the problem and it's a faulty part that needs replacing, search online for Samsung (insert wanted part number) to find suppliers that suit you best.
Punteggio 0
Aggiungi la tua risposta
James sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 5
Ultimi 30 giorni: 32
Tutti i Tempi: 334
