La Volkswagen Beetle è stata un'auto compatta prodotta dalla casa automobilistica tedesca Volkswagen. È stata introdotta nel 2011 come successore della New Beetle.
Could be a faulty oil pressure sensor or a problem with the wiring connected between it and the engine management control module, or worst case it's a faulty oil pump in the engine.
Best to get it checked out as you don't won't the engine to seize due to no oil lubricating it when it is running if it is the oil pump.
Hi @khotsochappie
What year is the vehicle?
have you checked the oil level on the engine oil dipstick to make sure that it is at the correct level?
da jayeff
Hi @jayeff
Thank you for responding.
I’ve checked the oil level and it’s on the correct level. Is there any other issue that could cause it
da Khotso Chappie
@khotsochappie
What year is the vehicle you never said?
da jayeff
I’ll do so thank you so much. It’s a 2014
da Khotso Chappie
