Salta al contenuto principale
Un portatile Dell XPS 15" 9575 (2 in 1), prodotto nel 2018.
How to replace internal keyboard?
I’m asking because I don’t know what to do at the stage when you see black polyethylene. I can’t find the complete replacement instructions.
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @galaxyvitas1143
Here's the service manual, taken from this support webpage for the laptop.
Go to p.52 to view the procedure to remove the palm rest and keyboard assembly.
Basically you have to nearly completely disassemble the laptop to do this.
Punteggio 1
2 Commenti:
Well, the instructions only show the entire keyboard block with the case. I just want to replace the keys inside
https://imagizer.imageshack.com/img923/4...
da
@galaxyvitas1143
You'll probably find that the keyboard is fused or riveted to the upper case, so you will have to either melt the plugs or drill out (break) the rivets that are holding the keyboard in place.
da
Aggiungi la tua risposta
Galaxyvitasa Galaxyvitasa sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 39
Tutti i Tempi: 411
