Salta al contenuto principale
La ottava generazione della Honda Accord
A/C Climate Control Switch Problem
A/C selector switch on climate control will not cycle on compressor and indicator light on switch does not come on. I saw where someone posted a troubleshooting procedure link but not for a 2012. Thank you.
Questa è una buona domanda?
Punteggio 0
1 Commento:
@bigfishtanner you've checked the instructions for the 2010 on here? The 2012 should be pretty much be identical. What differences have you noticed?
da
Aggiungi un commento
1 Risposta
Most likely switch is failed internally if the indicator light wont come on, but its also possible theres a fault in the wiring harness
Punteggio 0
Aggiungi la tua risposta
BigFish Tanner sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 21
Tutti i Tempi: 236
