Salta al contenuto principale
Guide di riparazione e supporto per dispositivi cablati o wireless che forniscono connettività internet.
Home WiFi not working
Good morning from Scotland. I am an EE WiFi customer. Our WiFi has not been working for the last few days. The router has a green light that should be turquoise. I have followed EE's advice on their website, switch it on and off again and reset it. Still no interwebs. Could some kind person please let me know if there is anything else I can realistically do myself to fix the problem? 🧐 Thank you in advance
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hi @heinzbeanz
What is the make and model number of the router?
da
Make: Smart Hub SH31B
Model: F5394-CP EE
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
Hi @heinzbeanz
If you've got the EE home app try changing the router's brightness value to 100% using the app and check if the colour changes to blue (turquoise?).
If it does, use a pin (paperclip) to reset the router and check if it starts up and connects to the internet OK.
If it indicates that it has connected OK but you're still not seeing the WiFi network on your phone (TV etc) then the router is faulty.
If it doesn't change to blue, then either the router is faulty or there's a problem with the connection to EE
Punteggio 2
1 Commento:
Thank you for your answer. I will try all this. Hopefully it works. However, big news as well. My wife finally reported it after 10+ days. Miracles do happen 🤣
da
The green light is probably the useful clue here. If EE says it should be turquoise, the router may not actually be getting a connection from the line.
Since you’ve already restarted and reset it, I’d check the cable from the router to the phone/connection socket and make sure it’s firmly plugged in. If you have another compatible cable, it’s worth trying that too. I’d also check the router’s status page to see whether it has received a WAN/IP address.
If the router still shows the wrong light after that, I’d contact EE and ask them to check the line. At that point it’s probably not something another reset will fix.
Punteggio 0
Aggiungi la tua risposta
Heinz Beanz sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 12
Ultimi 30 giorni: 32
Tutti i Tempi: 456
