Salta al contenuto principale
Xiaomi Poco F5 Rilasciato a maggio 2023 181g, spessore di 7,9 mm Android 13, fino ad Android 14, HyperOS Memoria da 256GB, senza slot per schede
How to replace lcd?
how to replace lcd
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Risposta più utile
This isn't really important, but just as a point of order before we start, your phone technically has an OLED display, not an LCD. Those are two very different technologies, with the OLED being newer, with higher resolution and uses less power.
Anyway, with your phone, like several Android phones, there are two ways to do a screen replacement. The first is to remove the screen by itself. This involves taking out the battery to access the display connector, then peeling off the connector from the phone's midframe, and finally separating the OLED display from the midframe. You then have to clean off the old adhesive, replace it with a sheet of precut adhesive or use some glue such as B-7000. This video shows the steps and procedures involved.
Poco F5 Screen Replacement - YouTube
The second method is a completely different procedure in which you purchase the screen already mounted to the midframe. That alleviates the issue of separating the old screen, cleaning it and regluing it, but it means you basically have to gut the phone and move all of the interior components to the new midframe. Generally I've found that the cost of the screen+midframe assembly is only a few dollars more than the screen alone; you often make that up when you have to buy glue. This is generally the preferred and safer procedure, but which one you use is up to you. Here's a different video showing the second technique.
POCO F5, habis jatuh,lcd nya pecah, begini cara ganti lcd nya, yuk simak proses ganti lcd poco F5 - YouTube
My apologies that neither of these is in English, but the one I found that was, wasn't of good enough quality that I could recommend it. Generally you don't need audio to follow along anyway.
Punteggio 1
Hi @keygaminghs
Here's a video that shows how to replace the display.
Depending on how much you need to replace, search online for either Poco F5 display module LCD + digitizer or Poco F5 display unit complete to find suppliers that suit you best. (supplier examples only)
Punteggio 0
Aggiungi la tua risposta
Key Gaming Hs sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 12
Ultimi 30 giorni: 85
Tutti i Tempi: 1,445
