Salta al contenuto principale
La Retroid Pocket Flip è una console videogame portatile con design a conchiglia. Esegue Android 11 ed è dotata di touchscreen da 4,7 pollici e controlli di gioco integrati.
Battery compatible retroid flip?
My original Retroid Flip battery ballooned overnight and I would need to buy a compatible (size and power) one to replace.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
@squeepty usually there are numbers printed on the battery with which you can identify the battery. Post some pictures of your battery with your Question so we can assist you with that. Aggiungere immagini ad una domanda Yours could be a 655093G 3.8v 5000mAh 3.8V battery.
If you can't find it by the numbers, measure your battery and then search for one (AliExpress etc.) for one that has the same electrical characteristics and dimensions to fit your Retroid. There can always be issues if these are custom batteries. If so you can always go smaller in physical size as well as mAh which will just lower the time your Retroid can be on battery usage.
Punteggio 1
Aggiungi la tua risposta
Squeepty sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 26
Tutti i Tempi: 449
