Salta al contenuto principale
Informazioni di riparazione per l'HP EliteBook 840 G3. Questo portatile Hewlett-Packard è progettato per l'utilizzo aziendale.
My display is glitching
I don't know if the problem is with the display or the RAM I will try to connect a external monitor later. When I am using the laptop while glitch screen it seems to get worse but it doesn't seem to compromise with the performance I hope it is an easy fix i think it's the problem with the display because few days ago I was carrying the laptop in my bagpack which was heavily packed
Questa è una buona domanda?
Punteggio 0
1 Commento
@arzaanali "glitching" i really not anything that describes what issues you are having. You do want to go ahead and give a better description of what the issues with your screen are.
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
Hi @arzaanali
Try this....
go to:
https://ftp.ext.hp.com/pub/caps-softpaq/...
Use HP Image Assistant (HPIA)
to download the correct drivers and bios update on your pc.
Run the tool and click Analyze
Allow for some time to capture system configuration,
and install all packages that was listed on it.
Punteggio 2
1 Commento:
I HATE HP the next day the glitching problem was solved but today the laptop is not starting when I plugged it in the capslock button and the power button keeps blinking pls help
da
My laptop display is glitching, likely due to physical pressure while in a tightly packed backpack, and although performance remains unaffected, I suspect a display issue and plan to test with an external monitor.
Punteggio 1
Aggiungi la tua risposta
Arzaan Ali sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 18
Tutti i Tempi: 413
