Salta al contenuto principale
Rilasciato il 22 novembre 2005, il controller wireless per Xbox 360 è il controller di gioco principale per la console videogame domestica Xbox 360 di Microsoft.
My controller is not working
Questa è una buona domanda?
Punteggio 0
10 Commenti
Hi!
What isn't working?
da
I don't know when i press the x butoon but controller is not on/working
da
Does it show the green light? Does any light burn? Do you use batteries or a rechargable battery pack? How does the battery springs look? Can you share a photo? Thanks!
da
No. yes i use cell .
da
Most likely motherboard related, or battery spings. How do they look? Still fine? No corrosion?
da
Mostra 5 altri commenti
Aggiungi un commento
3 Risposte
Soluzione prescelta
Thank you for the pictures!
All right. There is corrosion on it and thus it is recommended to replace them!
First, you need to de-solder those from the motherboard and solder new ones back in.
Second, the battery cover need to be replaced as well.
You can get the battery springs here: 5Pairs For xbox 360 Replacement Wireless Controller Battery Springs - AliExpress
You can get the battery cover here: 2-4pcs For XBOX360 Game Controller Battery Back Pack AA Battery Holder Cover Case Replacement for Xbox 360 Wireless Gamepad - AliExpress 44
If you have any more questions, please let us know!
Punteggio 1
4 Commenti:
No i did not want to change any thing tell me how to clean
da
You can try cleaning, the only thing you can do is to clean it with isopropryl alcohol. Hopefully that will get it back to work!
da
Hello i want to unlock my ipad air 2 without paswrod i forget my pasword tell my how to unlock
da
You mean the Apple activation “find my” lock? This cannot be unlocked. You need Apple for this. You need to show them proof of purchase and then they can unlock it for you. But please create a new thread for this. This thread is about an Xbox 360 controller.
da
Vedi il contenuto dell'immagine:
Punteggio 0
1 Commento:
Can you also show the back side where the battery springs are? Thank you!
da
Immagine
Punteggio 0
Aggiungi la tua risposta
Klamani sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 9
Ultimi 30 giorni: 35
Tutti i Tempi: 863
