Salta al contenuto principale
Kia Motors ha presentato la terza generazione di Sorento in Corea del Sud il 28 agosto 2014.
Infotainment scree not working
Hello all, require some guidance please.
i have a 2017 Sorento, 3.3 V6, base model.
The infotainment screen keep rebooting.
What i have done so far;
  • Hold the reset button for 30 or more seconds a few times.
  • Removed the battery connection ( + ) for about 30 seconds.
but both items did not fix the issue.
Thank you for your help in advance.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
So I would recommend removing the infotainment unit and checking connections going into it. Also, wh3n doing a global reset, or disconnecting the battery, id recommend doing it for 30 minutes to really give the capacitors time to discharge and reset. How long do you have between reboots? Do you have enough time to go in and do a factory reset?
Punteggio 0
Aggiungi la tua risposta
BooDoo sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 14
Tutti i Tempi: 212
