Salta al contenuto principale
Il tosaerba a spinta Craftsman 917.376551 è un tosaerba semovente a benzina dotato di un motore Briggs & Stratton da 6,75 cavalli. Presenta una larghezza di taglio di 53,3 cm (21 pollici), diverse opzioni di altezza di taglio e offre svariati metodi di gestione dell'erba tagliata. Questa pagina fornisce informazioni dettagliate e assistenza per la riparazione di questo modello.
Carb will not prime
Changed the oil on my mower and the float bowl is not getting gas. Brand new carb has been installed
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I believe this mower has a primer ball on the carb. I presume you have pushed it (at least the three times mentioned in the manual (and you can or can't feel whether it's picking up any gas). If it's not picking up gas when pushed, check for obstruction or kinks in the fuel line from the fuel tank to the carb.
Have you tried removing the air filter, squirting a little fuel into the throat of the carb, replacing the air filter and then trying to start it? Sometimes that's all they need to get primed. If it starts, then dies, try it one more time. If that doesn't work, I'd look for an air leak in the fuel line (it may be drawing air instead of fuel). When using this method (you may alternatively squirt a little fuel directly into the spark plug hole and replace the spark plug), if the engine fails to fire at all, you're probably looking at no spark. Just be careful when spilling fuel! Do this outside!
Punteggio 0
Aggiungi la tua risposta
Ask sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 12
Tutti i Tempi: 189
