Salta al contenuto principale
Trova informazioni sulla riparazione e altro sul frigorifero LG LFCS27596*, un modello del 2019 dotato di sbrinamento automatico, senza distributore integrato nello sportello né produttore di ghiaccio. Questa pagina copre le informazioni per i numeri di modello che corrispondono alla serie LFCS27596*.
CF E code after fan replacement.
I replaced the condenser fan on my fridge when this code popped up. It worked fine for like 24hrs then I noticed the sides of the fridge were hot again and it was throwing the code as well. I unplugged it and let it sit for about 10 minutes then plugged it back in and spun the fan my hand and it started working again. Now it is off again when I checked it about 16hrs later. Any ideas on what would cause this because I am out of ideas. Thanks for your time
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @dylanmcguire
A CF E error code indicates a problem with the condenser fan or condenser fan operate circuit.
Here's the start of the CF E troubleshooting section of the service manual that may help.
It the replacement fan is the problem, search online for EAU63923602 to find suppliers that suit you best. This is the part number for the condenser fan and it should be printed on the fan itself if you wish to verify that it is the correct one.
Immagine Ensures optimal airflow across the condenser coil in LG refrigerators by rotating when activated.
Prodotto
LG Dc Motor Assembly - EAU63923602
$93.99
Punteggio 1
Aggiungi la tua risposta
Dylan McGuire sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 26
Ultimi 30 giorni: 74
Tutti i Tempi: 924
