Salta al contenuto principale
L'Acer Nitro 5 AN515-58 è la versione del 2022 della serie Acer Nitro 5. Questa guida dovrebbe essere compatibile con tutte le varianti dell'Acer Nitro 5 AN515-58.
How do I replace my CPU and GPU fans
Yeah so I need to replace my fans on my Nitro AN515-58, I’ve tried cleaning the fans, didn’t work, fairly new to this stuff so I might need detailed instructions or a video.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @cluelessperson
Here's a video that may help.
To find replacement fans, check for any model number or part number information that may be on the fan itself and if there is, search online using that information to find the correct fans for the laptop.
If there is no information on the fans themselselves search online for Acer Nitro 5 AN515-58 fans, but ensure that they specify the complete model number and not just the model series.
Note: Ensure that you disconnect (unplug) the battery cable from the motherboard as soon as you can access it after opening the laptop to minimize the possibility of causing any electrical problems on the board during the repair. Reconnect it last thing you do before closing the laptop after the repair is complete,
Punteggio 2
Aggiungi la tua risposta
Cluelessperson sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 43
Tutti i Tempi: 771
