Salta al contenuto principale
Il controller Xbox One è stato introdotto nel 2016 con il lancio di Xbox One S e aggiunge il supporto Bluetooth per Windows 10/11. Questo controller corregge molti difetti di progettazione riscontrati nei modelli 1537/1697 ed è molto più affidabile. Questo controller è stato sostituito dal migliorato controller Modello 1914.
Xbox says controller is disconnected
My Xbox continually says that my controller is disconnecting, even though the light on the controller is still on. I’ve used 3 controller, multiple batteries. I’ve used the USB port in the xbox to charge the controller and it still happens. I’m not exactly sure if this is an Xbox issue or a controller problem. I ordered a new xbox controller and its currently on the way so maybe that will fix it. But any idea will be greatly appreciated. Thank you.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Can you confirm if you are connecting this to an xbox console or PC please?
Also, can you confirm if what you are using to connect the controller, is it always wireless or do you ever use a USB type cable?
Also, are you using battery packs, as in a pre-made after market battery rather that the traditional AA size standard batteries?
Thanks in advance for your answers :)
Punteggio 0
1 Commento:
It is an Xbox one console. It is a wireless controller but i have used the USB port in the console to charge the controller and still no luck. I mainly use battery packs but even with the issue I’ve been having it happens even when I’m using packs or AA batteries. Thank you!
da
Aggiungi la tua risposta
Nathan Tarr sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 9
Tutti i Tempi: 262
