PC will not boot up
I hit the power button, fans turn a few times but won't start up. Sometimes the RGB lights turn on but nothing else.
Questa è una buona domanda?
It’s sounding like your PC is having a power issue. Here are a few troubleshooting steps to attempt:
Check the Power Supply (PSU)
Make sure that the power cable plugged into the wall outlet and into the PSU is firmly in place.
Use an alternate power cable or wall outlet.
If you have a PSU switch (I/O) turn it off and on.
If possible test with another PSU.
Check for a Short Circuit
Turn off and disconnect everything.
Open your case
Well you can try the following:
Your PC may have a power supply, motherboard, or RAM issue. Try these steps:
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 19
Tutti i Tempi: 430
Hi @zombieslay72601
What is the make and model number of the PC or motherboard if it is a custom build?
da jayeff
