Salta al contenuto principale
Informazioni su riparazione, smontaggio e soluzione problemi per la Xbox Series X 2 TB Galaxy Black Edition. Rilasciata insieme ad altre console videogame Microsoft aggiornate il 15 ottobre 2024.
Where Should I Start?
Hi!
I'm looking to get started into computer repair as a hobby and possibly turn it into a professional set up.
I'm looking to start with games consoles as I'm most familiar with those and fix issues with my personal ones with the intention of learning and progressing.
What toolkit would you reccomend for someone that is new to this field? I
Thank you in advance!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi!
Start with the Ifixit Pro Tech toolkit. There is a lot in there and usefull for the game consoles. You also need solder equipment. So, the soldering iron is recommended as well.
Just start with the Pro Tech toolkit. It’s possible that you will miss some things (like the Xbox 360 opening tool). You will most likely get new hardware by learning over time which tools are required for the game consoles.
Punteggio 2
4 Commenti:
Hi!
Thank you for your helpful reply!
I'm just starting out small and fixing issues with my own controllers (PS4 & Xbox Series X Stick Drift) I bought the Xbox Toolkit and will attempt at a fix the issue. I will certainly buy the Professional ToolKit, so soon after Christmas isn't quite possible currently 😅
I've watched tons of YouTube videos and hopefully can fix both without needing to "operate".
I see you have lots of useful guides on your page and I hope to learn from them and take notes to have on hand 😊
da
My pleasure! Ahh, yeah then you do need the soldering iron and the Pro Tech tool kit! Hopefully I can help you with my guides! Thank you for using them! I wish you good luck with the repairs!! If you have any questions, please let us know!
da
Update:
I managed to strip and repair the Stick Drift in my Xbox Controller and also PS4 Controller. Also fixed L2 which just needed to be realignment.
Thank you for the tips!
I plan on Cleaning my Series X and fixing a button my Nintendo Switch over the coming days, just need some Isopropyl Alcohol 😊
da
My pleasure! Good to hear that you fixed that already! Keep up the good work :)! Yes, cleaning with isopropyl alcohol will help you a lot! Good luck again :)!
da
Aggiungi la tua risposta
SimonLynch sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 21
Tutti i Tempi: 324
