Salta al contenuto principale
Informazioni su riparazione, smontaggio e soluzione problemi per Xbox Series S, la console videogame digitale di Microsoft dal nuovo fattore di forma compatto. Xbox Series S è stata pubblicata insieme alla sua sorella maggiore più potente, Xbox Series X, il 10 novembre 2020.
Stuck thinking it has wired connection
I have recently had issues with a thunderstorm that took out my internet connection and since my Xbox thinks it still has a wired internet connection but wouldn't connect to internet to play games. 8 tries resetting the settings and it won't go to wireless internet as it thinks there is a connection in the LAN port when there isn't. I then reset the console but now won't do the required update when setting up the console from factory settings. I even tried usb boot drive and no dice. Any help would be greatly appreciated.
Questa è una buona domanda?
Punteggio 0
2 Commenti
Have you been able to find a fix? This just happened to me. I ordered a new wifi card to see if that fixes it and it comes in today.
da
Mine is fixed. Turns out after a complete drop down including all software updates it turned out to be a ribbon between the 2 last boards to split.. deepest ribbon cable 🤬🤬
If your UK based and have the same issue these guys will tell you all about it ( Mansfield Tech Hub )
da
Aggiungi un commento
2 Risposte
Risposta più utile
Hi Gareth!
Did you tried an actual network cable and see what happens? I would try this first. Just go to your modem and connect it with a network cable just to check. When it does have network, then you can do the actual update(s). Then remove the network cable, maybe the error would be gone by then.
Please let us know how it goes!
Punteggio 1
2 Commenti:
I have the same problem and multiple network cables and days and it still says the same
da
Please sent us some photo's regarding the error.
da
Punteggio 0
Aggiungi la tua risposta
Gareth M Clifft sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 12
Ultimi 7 giorni: 40
Ultimi 30 giorni: 168
Tutti i Tempi: 2,205
