Salta al contenuto principale
No Network Coverage problem
Why do I have no network coverage?
I'm pretty sure the phone is properly unlocked and i put my sim card in and activated it on my
Immagine
phone plan and no matter where I go (places where on other phones i get great coverage) i get no signal, the simcards network providers are being detected but the network bar is always empty. Is this an issue with the phone, the carrier, unlocking, or just a bad antenna? what do i do to fix the problem?
Questa è una buona domanda?
Punteggio 6
4 Commenti
Hi @samxo247
Can you try a different provider's known working, compatible SIM card in the phone to check if it is unlocked on not?
da Condividi
@jayeff Thanks Jayeff, the phone is unlocked, I've tried different simcards of different providers but the result was the same
da Condividi
@jayeff yes it was working at first, this happened after resetting the whole phone system, and I have tried the network resetting just now, it didn't work
da Condividi
My phone it's not working any sim card it's oppo a74 5g
da Condividi
Aggiungi un commento
2 Risposte
Risposta più utile
Hi @samxo247
Has the phone connected and worked OK before?
If you haven't already done so, try a network reset and check if that resolves the problem. Here's a video that shows what to do.
Punteggio 1
2 Commenti:
@samxo247
Did you factory restore it with the SIM card inserted?
If so, remove the SIM card and factory restore it again. Once it has fully restored, insert the SIM card and check.
da Condividi
I try all of this
da Condividi
Phone ki body change and network issue
Punteggio 0
Aggiungi la tua risposta
Sam XO247 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 9
Ultimi 30 giorni: 36
Tutti i Tempi: 1,470
