Salta al contenuto principale
Scopri le informazioni di riparazione, incluse guide e suggerimenti, per cucine, forni e piani cottura GE. Offriamo istruzioni dettagliate per la risoluzione dei problemi e la riparazione di guasti comuni in vari modelli di cucine e forni GE.
Ge monogram oven problem
Probe light kept blinking on and off on display and couldn't start oven. Replaced probe and receptacle, still blinks. Should I replace the control panel board or main machine board?
Questa è una buona domanda?
Punteggio 0
3 Commenti
This question was migrated from https://meta.ifixit.com/Answers.
da Condividi
Hi @bob57707,
What is the model number of the oven?
da Condividi
@jayeff hi, model number is zet1sh1ss
da Condividi
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @bob57707
Here's the mini manual for the oven.
It shows how to test the temp sensors to prove that the sensor wiring and the sensors are OK back to the board, - see Oven Sensor and Door Switch Ohmmeter test on p.1
If they test OK run the service test mode as described on p.2 and check what error code is shown (if any) when testing the components.
If a part is faulty and needs to be replaced, here's a parts list that is useful as it shows the manufacturer's part number listed for each part.
Search online for the part number only to find suppliers that suit you best.
Punteggio 1
Aggiungi la tua risposta
Bob sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 18
Tutti i Tempi: 513
