Salta al contenuto principale
L'Oppo Reno7 5G è uno smartphone progettato da Oppo. Il telefono è stato rilasciato nel 2022.
How to fix screen touch sensitivity
when playing games sometimes its hard to press because it doesnt function. And sometimes the touch screen had delays
Questa è una buona domanda?
Punteggio 10
1 Commento
My phone is very hot.
da Condividi
Aggiungi un commento
2 Risposte
Risposta più utile
Hi @onij
Set the adjustment of the Touch and hold delay setting to what you want.
Go to Settings - System settings - Accessibility - Personalized settings - Touch and hold delay.
If you can't find the setting, to turn on the Accessibility and menu settings go to Settings - System settings - Accessibility - General - Accessibility Menu. To open the Accessibility Menu, tap the icon in the lower right corner
Punteggio 2
Battery repair
Punteggio 0
1 Commento:
Fateh, you're going to have to give us more than two words if you want help. By "battery repair", are you saying you want to replace the battery? Is your phone the same as that of the original question? Have you verified the battery is the problem and not the charger, the cord or the charging port? Have you tried a different charger?
da Condividi
Aggiungi la tua risposta
ONiJ sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 15
Ultimi 30 giorni: 69
Tutti i Tempi: 4,560
