Salta al contenuto principale
Le serie JVC FS-x0000 e FSMD9000 sono sistemi HiFi compatti con una qualità sonora impressionante.
How to fix dim led light?
Can read the display because the led light is burned out
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @johnhutton75635
Looking at p.2-27 (48 of 82 pdf numbering) of the service manual it shows the display is lit by a fluorescent tube and is most probably integral to the display i.e. not separately replaceable.
It could be that there's a problem with the power supply to the tube (see FL driver section on page - components Q7795 and Q7796) however, so maybe that's worth checking first.
The display module doesn't seem to be listed in the parts list at the end of the manual, but I think it may be model number QLF0048-001
If the power supply to the display FL tube is OK, you may have to replace the display module if you can find one that's in stock. I couldn't.
Punteggio 1
Aggiungi la tua risposta
John Hutton sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 20
Ultimi 30 giorni: 42
Tutti i Tempi: 530
