Salta al contenuto principale
Il Palm Zire m150 è un PDA portatile con touchscreen. È stato prodotto da Palm nel 2002. Il PDA è dotato di 2 MB di RAM e 2 MB di memoria installata.
Acceptable Battery Replacement on Amazon?
Hello :)
I recently got hold of a Palm Zire m150, but the battery is no good. I found a replacement battery on Amazon: (https://www.amazon.com/GAXI-Battery-Repl...). I would think that this is the right battery, but I am just making sure (for the safety of me and my Zire).
Thank you!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
There should be nothing wrong with that battery - I've used CS batteries many times with no issues.
Just note that this battery requires soldering, and be prepared for that.
The seller is someone called "GAXIN" and they have a very short duration on Amazon and little feedback. Not sure if you can find some equivalent from a more reputable vendor. Not that I am saying anything bad against GAXIN, they may be a perfectly reputable vendor just getting their start. But until you know, or they've built a good reputation, you simply never know.
Punteggio 2
Aggiungi la tua risposta
_nec6678 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 20
Tutti i Tempi: 320
