Salta al contenuto principale
Samsung Tablet from 2021. The model number is SM-X200 or SM-X205
7 Domande Visualizza tutte
Tab A8 Screen won't turn on after replacing lcd flex cable.
Hello, I own a tab a8 and my screen became lose from the adhesive and the screen fell off and when it fell off, the Lcd flex cable ripped in half while the tablet was on.
Ive bought two different lcd flex cables and tried both and neither have worked.
the tablet screen wont turn on at all. any help is appreciated, thank you.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi, You should make sure the new cable is not torn or damaged. You can also try reseating Both ends of the cable. You should inspect the display to make sure that the connector on the display is not damaged. It is also possible that the display cable caused a short and fried the tablet.
Best of luck, BetaTech Labs Repair AU
Punteggio 2
2 Commenti:
Thank you for your response, unfortunately i've tried the things you mentioned and my tab a8 still didn't work so i guess the tablet is fried. I guess my best option would be to buy a new tablet. thank you for your help
da
I'm sorry that it failed. At this point my guess is motherboard is messed up.
Best of luck, BetaTech Labs AU
da
Aggiungi la tua risposta
Anonymous_Bozo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 26
Tutti i Tempi: 264
