Salta al contenuto principale
Modello A2159, EMC 3301. Un aggiornamento del MacBook Pro 13" entry level. Disponibile in argento e grigio siderale. Lanciato a luglio 2019.
Original Battery not recognized
Hi,
I was assembling my macbook pro 13" 2019 and I have this problem: my macbook not recognized the original battery.
Have I damage the battery flex data cable? because, I pulled of this flex cable and I did not open the connector flex of the mainboard.
Photos:
Immagine
Immagine
Immagine
Thank you,
Update (05/03/24)
Continue:
The only way to turn on my macbook pro is: connecting it to the electical network with my power adapter.
Thank you
Update (05/03/24)
Hi Dan,
Photos:
Immagine
Immagine
Immagine
Immagine
Update (05/06/24)
Hi
I have already had a new flex cable !!! and I have just fixed my macbook pro !!!
Thank you for all answers !!
Questa è una buona domanda?
Punteggio 2
3 Commenti
So the only way to use it is to plug it into the wall?
da
Exactly! That is the only way to use my macbook...
If I install Cocunut Battery... It will show "nan"
da
Both connectors seem to be fine and their tabs too, so is it possible that I have damaged the flex cable or the connectors of the mainboard?
I hope I have damaged only that cable...
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Can you post images of both connectors so we can see if they are damaged. If it’s just the cable that’s replaceable MacBook Pro 13" Retina (A1708, A2159, A2338) Battery Daughter Board Cable
Immagine Replace the small flex cable that connects the battery daughter board to the logic board.
Prodotto
$16.99
Punteggio 1
4 Commenti:
Hi @danj,
Very close to being a short circuit between connector pins 9 and 10 (from the left) in the 2nd image posted above.
What do you think?
da
@jayeff - I would replace the cable for sure, but the real issue is what happed within the connectors.
da
@consu - Looking at the connectors they look OK, so maybe all you’ll need is a new cable! I wish you luck!
da
Thank you so much for your point of view!!
I will write here when I have the new Flex Cable.
da
Aggiungi la tua risposta
Consu sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 26
Tutti i Tempi: 475
